drbulldog
Hey guys. Im moving into a new pad. Need help setting up the right HT setup. My question here is on speakers: I need help choosing between essentially 2.
Room: a little more than 300sqft. Wooden floors. But there is an open kitchen which is an additional 100sqft. but the main listening area is the above spec.
I will be listening to music as well as watching movies on a 110inch Projector. sitting 14.5ft from the screen and speakers.
I've tested and narrowed down to two:
1)B&W 703
2)KEF XQ5's.
or
3)B&W CM7
Basically I can get the XQ5's for hundreds cheaper than the 703's.
I like my music nice clarity with depth; movies much the same. I listen to some jazz and r&b. Which is the better speaker for me. Or do you have more to recommend??
mike c
mike c
down to two? are you getting BOTH item 1) and item 2) vs. item 3) only?
