I have just purchased the Samsung LN-S4051D
Connected to the TV are Xbox 360, ps2, DVD player soon to be replaced with the oppo DV-981hd
Now on the audio side of things I have a Pioneer sx-2900 receiver, Pioneer pd-m501 6 disk changer and the speakers are KLH av-4001 (these components are old school, at least 10 years old)
I was looking to upgrade now that I have the new TV. I was initially looking to some of the home theaters in a box but then I found the audioholics web site. I was planning on spending $1000-1500 but im not sure I can get what I want for that price range.
Due to the size of the room I was thinking a 2.1 or a 5.1 system. also due to the fact that it is on the second floor I dont have the option to put the speaker wire under the floor so is there another way to get the speaker wires to the back of the room with out having to go through the walls or have the wire run along the walls? i would also like room to expand in the feature. as for a receiver and speakers im not sure what to get for this price range.
i have looked at just about every brand recommend by audiohoics regarding speakers, receivers, DVD and im lost.
budget: speakers $500-900 receiver $500-900
also i was just wanted to know if it is possible to just do a front left, center right and sub set up and if so will it sound good?
