New to the Audio world. Need some help with setup pls
K
Kaizor
I hope not to get flamed because of my questions, just a fyi i am completely new to the audio world and i am trying to figure out how to get this system setup that i purchased recently. thanks in advanced for any replies and help i get.
Ok here is a picture of the room i made the size is roughly 12 ft in depth and 20 in length.
Now i have a large sofa i plan to put on the top right corner of the room. and i have a lazy boy recliner i have no clue where to put it because i am going to put it somewhere after i got the system setup.
Here is the system i bought:
50" Sony Wega KDF-E50A10 with matching corner stand
Paradigm Monitor 9 speakers
Paradigm CC 290 center speaker
Paradigm ADP-190 surround speakers
HSU VTF-3 MK3 Sub woofer
Now i was thinking of setting up in the top left corner but then i realized i wont be sitting in front or the tv or centered with the system. i am completely confused. If anyone can help out with some options or just tell me im screwed that would be great lol.
Thanks for your time and help
sorry if i left some details out. please ask
ParadigmDawg
ParadigmDawg
It looks like you have two big, empty walls available but then again I dont think you attached an actual picture of the room.;)
K
Kaizor
Well the room is getting remodeled so i cant take any as of right now it is such a mess and so much stuff everywhere. maybe i should have waited but yea i tryed my best with the little drawing my bad.
Yea the 2 side are walls i forgot to add that to the drawing.
i will post a picture of the room as soon as i can.
ParadigmDawg
ParadigmDawg
From what I can tell either one of those walls would be great. Nice gear you got there; I am sure you will enjoy it. Lay it all out without hooking it up and set in front of the TV and look for pros and cons of a couple of different set-ups.
jimfitz
I see about 6 options. Put the monitor on either end wall, top left corner, top right corner, top left wall beside windows, top right wall beside windows. The room is so long that you can break it up into 2 seating areas. Center the seating in front of the monitor on one end of the room and make another seating area on the other end of the room. Don't be afraid to angle a couch if you put the monitor in a corner.
K
Kaizor
Thank you both of you. now that i read some other options, ideas are popping in thanks again will update and let you know how it goes. now i just need this room done lol.
AVRat
AVRat
I think I'd orient it facing the right wall with the sub under the chimney column (if that's a good sound location). I'd place the ADPs facing each other about 18" to the left of the windows about 6' up at the tweeter. For a 50" display I'd consider a 9' - 12' viewing distance.
