Looking to install klipsch speaker system in my den.
It will double for my movie room
I have looked into many setups, tech specs, etc and really need someone to review my setup and ask me question like " have you considered this" or " you may not need "X"", or "for your room size you really need more "X"".
I really don't have any immediate "real" friends that are audiophiles and I,m sure am not at that level - yet.
Room:
30 length x 15 width, x 8.6 ft height
Will have wall to wall carpet (no shown in pic)
Fireplace/stone on one wall
Position of TV is offset towards the fireplace (see pic and black plastic on wall)
Room will have a normal fabric couch, love seat, and maybe a leather chair, and a side table.
Couch to tv distance will be about 12feet (if couch is set off away from the window.
Also will have table underneath the tv to house the AVR and the tower speaker will be on side.
Window treatments will be cloth roman shades but no curtains.
Overall wants:
Excellent surround and movie sound effects.
More for watching movies/tv than for listening to music
Budget is around $2500 - 3000 (speakers/avr)
4K compatible (hdcp2.2, hdmi2.0)
Background:
I decide to go after a 5.1 system vs 7.1 and focus more on high quality surrounds versus lesser quality/price and another set of surrounds
Plus the 7.1 surround would be in the ceiling (which I think is not optimal firing down on listeners)
Choose not to go with in wall speakers, although I prefer the clean lines, I just never go convince my walls would produce optimal sound effects.
Pics show black plastic for position of the 70 inch TV (it's at about 45" off floor)(good for me)
Pics show black plastic on each side of window for the surrounds (they are about 81 inches off floor to the center of speaker)
Sub position is to left of tv half way to the wall (outside the front left speaker)
Here is what I have chosen:
RP 250F towers for L/R fronts
RP 440C center channel
RP 250S surrounds
R115SW
(TV is Visio 70 inch M series - 4K)
AVR: Onkyo TX NR838 at 0.08 thd, AccuEQ, this is a 7.1 avr (using the 7.1 part to send sound to outside speakers)
Spec on this is 130Watts ((into 8 ohms at 20hz-20khz, at 0.08%thd, driving 2 channels)
?Will this be enough power?
?Will I need separate amp for my 5.1 set up?
If you can provide me with your expert opinion that would be great.
lil ed - North Carolina
