I am in the market for a new receiver and also some new speakers for my basement. I went to a local A/V retailer in my area and liked what I heard. They set up the Integra DTR6.8 surround sound receiver with Monitors silver line speakers, it sounded awesome. The price roughly $4000. My question to you is: 1) is this a good choice 2) what would you recommend for this price. Hopefully I receive some good input, I would like to go ahead and order ASAP! Thanks
Thats great that you found something you liked. My question to you is do you want to spend that much? Is that what you are budgeting for? You need to sit down and think about how much you want to spend. What if you came across a system that was $1000 cheaper and sounded as good or better? Know what I'm driving at? The fun stuff is auditioning speakers. One should choose the speaker 1st before the amplifier becuase the speakers will determine how "beefy" an amplifier/receiver that you need.
Here's what I did when auditioning speakers:
What I would do is to take a pad of paper with you, write down the make and
model of each speaker you audition and what you liked and disliked about the
speakers you were auditioning. Was the bass tight and deep or was it boomy and loose sounding? Were themids life like or were they hollow or just too pronounced? Was the trebleirritating and harsh or were they dark and not revealing or were they smooththat made you want to listen for more? How was the imaging?
Bring music with you that you are very familiar with and know quite well. To
make it easier to audition HT speaker systems, listen to the main speakers in 2
channel mode with music. Music is much harder to reproduce acurately then a movie soundtrack so if the speakers do well with music, then they will do well with HT. Speakers that do HT well may not do well with music. When auditioning the center channel of the same brand and series as the main speakers, pick a difficult source like an announcer that mumbles alot. If you can makeout what the mumbling announcer has to say, then you have a good center channel.
I would go to speciality stores first and start auditioning speakers first
instead of going to the internet first. Once your likes are determined, you can
mention them here and fellow members can make internet brand recommnedations based on your likes/dislikes.
The specality stores are better setup acousticaly then the big box stores which will make auditioning a little easier. It will give you an idea of what you like in a speaker.
Keep track of what amp or receiver is powering the speakers you're auditioning. Try to get a receiver/amp that closest resembles what you have or want to get. It just reduces another variable when audtioning speakers.
One thing to keep note off. When auditioning speakers, make sure the volume
levels are matched between the different speaker pairs because the louder
speaker pair will always sound better. Listen to levels that you think you
would listen to most of the time because thats how you are going to be using
them most of the time.
Hope this helps
