Silent Zombie
Hi,
I just purchased a Yamaha RX-V367 receiver with Pinnacle MB 6000 speakers. Using bare 14 gauge wire to connect everything and HDMI for all of my devices. One problem I am running into is that I have to crank up the volume on this receive to -9.5 DB (Max is +16.5 on this receiver) before I really start getting loud sound from the speakers. I have spent hours trying to configure and nothing seems to help with increasing the actual sound level from the speakers. I expected more and I wasnt sure if maybe these two just were not meant to be together. Or could it be the gauge of wire or even the size of my living room?
My living room has vaulted ceilings and is very large.
AVRat
AVRat
Welcome to the site. While I would say that that type system would be appropiate for a room under 2000 cu ft, there should be no problem running the receiver at that level unless you start to hear distortion or it experiences excessive heating. The receiver should shutdown before overheating becomes an issue.
GranteedEV
GranteedEV
Hi,
Here's how the volume control on a receiver works as far as I know.
First it during auto setup it will determine the sensitivity of your speakers. It will use that sensitivity to decide on how much power is necessary for "reference level".
Now reference level, in dolby terms is 105db for speakers and 115db for low frequency effects in movies at the seating position.
Some receivers will use 10db below that, and further give you an option to have the reference level for a subwoofer to be identical to the speakers (a -10db LFE option)
Next we get to actual recordings. They use that 105db as "the loudest it should get at the seating position". In general movies will be recorded 20db below this, IE, 85db "average" volume or with some receivers, this will be 75db (as the reference volume is 95db). I'm not quite sure as different brands operate differently and I have better things to do than take an SPL meter and see how random receivers operate. Actually I just can't afford an SPL meter.
So anyways, we treat 85db (or 75db) as "average volume" when the "volume" on the receiver is set to zero.
However this does not factor in the recording itself. Some recordings can have an "average volume" which is 40db below reference etc.
Now consider this.
If a speaker has a sensitivity of, maybe 91db/2.83v/m, at a distance of around 2m you will only require 1w of power in an 8 ohm load to get your speakers up to 85db! This is extremely loud!
So in order to get that 85db average volume, you would need to make the dial on the receiver all the way up to "0". Yet for a mere 100w amplifier, you've still got enough amplification available to add 20db of gain for loud transients. That means that a 91db sensitive speaker will get you 105db peaks at a 2m listening distance with 100w of amplification.
So in reality, even though -10 on the receiver may seem high, you've probably got around 20-30db of dynamic range "on tap". Those are ear-bleedingly loud levels.
So even though "0" may be the limit of the receiver as far as "dynamic range", it may not "on average" sound as loud as you might imagine. It all depends on how compressed the dynamic range in a recording is. The more compressed, the closer to "0dbFS" the average sound is.
Here's some cool recordings with lots of dynamic range (scroll to the bottom):
http://www.danleysoundlabs.com/technical downloads.html
Disclaimer: If you turn it up loud enough to "hear" the quiet stuff you may destroy your system and ears on the loud stuff. It's for people with systems that dwarf most of ours in output capability.
GranteedEV
GranteedEV
One other thing I thouight I'd mention.
DB is not a linear scale of sound... I believe it's exponential. Every 10db represents a doubling of perceived sound.
if -70db is the lowest your receiver goes, that means the loudest stuff will be something like 25 or 35db (70 db below 105db) and the average stuff will be around 5 or 15 db (practically inaudible)
-60 should sound twice as loud assuming the scale on your receiver uses decibels in terms of SPL. Twice as loud as inaudible isn't really very loud. So the whole first 40-50db on a receiver is usually for quiet listening. for me, my comfort listening is usually from -25 to -6 on the receiver, depending on the recording. At night I can deal with around -36 on the receiver.
So basically from -70 to -36 i have a bunch of unused "points" too.
Here's a good page to read:
http://www.eltoroairport.org/issues/noise_levels.htm
Silent Zombie
Thank you very much for the response. So based on these speakers and the receiver you don't think its either device just that I might be a little to reserved on turning up the volume? I am worried about blowing the speakers and I am not sure if this receiver has a fail safe to prevent that.
AVRat
AVRat
Personally, if your room is large (what are the dimensions?), that setup is probably straining a bit. Generally, most people with systems calibrated to reference listen with the volume setting around -14 - -22 which can be extremely loud depending on the room’s spatial volume. I listen between 15-18 depending on the soundtrack and my channel levels are set at about -4dB. My L/R speakers are about 6dB more sensitive than your Pinnacles which means they play louder with less power, which also contributes to why you have to turn up the volume.
U
Undedaabild
Оцените сайт
ходатайство ко всем, оцените выше сайт barbos tv, сайт недавний и нужен совет обычных пользователей , Чего не хватает? Сколько не понятно?
U
Undedaabild
Оцените сайт
ходатайство ко всем, оцените наш сайт barbos tv, сайт недавний и нужен синод обычных пользователей , Чего не хватает? Который не понятно?
U
Undedaabild
Оцените сайт
просьба ко всем, оцените выше сайт barbos tv, сайт недавний и нужен общество обычных пользователей , Чего не хватает? Сколько не понятно?
U
Undedaabild
Оцените сайт
прошение ко всем, оцените наш сайт barbos tv, сайт недавний и нужен общество обычных пользователей , Чего не хватает? Который не понятно?
U
Undedaabild
Оцените сайт
искательство ко всем, оцените наш сайт barbos tv, сайт новоявленный и нужен синод обычных пользователей , Чего не хватает? Что не понятно?
U
Undedaabild
Оцените сайт
ходатайство ко всем, оцените наш сайт barbos tv, сайт новоявленный и нужен общество обычных пользователей , Чего не хватает? Что не понятно?
