Yes I am running 2 sub presently, both JBL PB10 , one from the AVR3805 sub out (LFE), the secound sub from the left and right speaker cables and the M80ti will be connect from the sub amp. Just in case it matter I am set up to run my 3805 as 7.1...(no zone B)
I don't run any exotique cables, I always belive in good but not over the top exotoc cables. Right now I have 12 gauge , 35 feet long speaker cables.
95% of our time they will play will be to watch movie, so rarely we will watch more that 2 1/2 hours at the time (exception of LOR) So the 3805 will rarely run for more that 3 hours and never more than 6 hours. (I don't think I be able to watch more that 2 LOR in a row)
The ventilation is very good, 6 inch on the top, 3 inch on each side but more than 18 inch at the back and no door in front. I always tought that less ohm that what then receiver is rated, was very bad, but to much ohm was okay.
If I sum all the advice I got so far, the 3805 and M80 should get along, I should keep a eye to make sure the 3805 heat up and dont drive the speaker too hight, too long . I will not be able to test this theory for a other 2 weeks, (my basement have been flood in Sept one inch and half, and it will be fix in the next 2 week) if any one have other good info, fire ahead.
Thanks for every one advise so far.
