New Reference Recession Buster
That's a very unusual looking tweeter.
*edit - cabinets additional cost, but still reasonable.
sawzalot
sawzalot
I believe it to be just the cabinet plans , buyer supplies cab. material and assembly.
*EDIT just saw your edit, sawz..
lsiberian
lsiberian
i didn't see any cabinets. Madisound usually does driver/crossovers only. Most of their customers build their own cabinets.
In the Order pull down, there is an option for cabinets for +$62 for ported and +$49 for sealed, or X-over and drivers only. I would hope that cost is for actual cabinets, not just the plans :)
Alex C
Optional Accessories Package
*Select from drop down menu above*
*Everything you need (besides the cabinet) to build a complete a pair*
*Includes a 10% discount on all the parts*
Ported Enclosure Accessories Package
* (4) BG-POST Gold Plated Binding Posts (2 Red & 2 Black)
* (2) 2FLARE 2” Flared Ports
* (8ft) Supra Classic 1.6 (15 AWG) Internal Speaker Wire
* (.2lb) Acousta-Stuf for lining the rear wall
* (1) Foam Sheet 27” x 42” x 5/8” for lining the side walls
* 1 Goop for gluing foam to walls & 2FLARE parts together
* 2 QC110B Quick Connects for – tweeter tabs
* 8 QC187R Quick Connects for + tweeter & + crossover tabs
* 6 QC187B Quick Connects for – crossover tabs
* 4 QC250R Quick Connects for + woofer & - binding post tabs
* 4 QC250B Quick Connects for - woofer & - binding post tabs
* 18 Socket Head & Philips Head Wood Screws for mounting drivers to baffle
Sealed Enclosure Accessories Package
* (.5lb) Acousta-Stuf for lining the rear wall
lsiberian
lsiberian
That makes it easier to order all the little accessories they suggest.
