I presently run my system through an H/K AVR 330 that I've had for a couple years. Since purchasing it, I've upgraded most of my system with the equipment listed in my signature, except for the TV (prior purchase). Overall, I've been very pleased with the 330. My only beef is that at 55X5 wpc, it could be a tad stronger in the output department. To calibrate to Dolby reference, it requires a master volume setting of -5 with a little room trim up if needed. I've never overheated it, but it puts out enough heat during a DVD concert to keep the room toasty!
However, looking to the future, I see the need to upgrade.
I use the 330 as a video switcher, however it will only handle component, not HDMI. To complicate matters, the only digital input on the TV is DVI, so I spend a lot of time switching inputs on the TV from sat box (component) to DVD (HDMI into DVI)
The TV likely isn't going anywhere for a while, as it's only 4 years old. I recently won a 2-port HDMI switcher off here that I could integrate and solve some spaghetti wiring problems with;
negating the need for an HDMI receiver for a while longer.
I guess my real question (I'm prone to rambling..sorry!) is should I scrap the 330 in favor of something like the Onkyo TX-SR605 for about $450 or just add a small amp to give my Athenas a little boost while taking some load off the 330? The 605 would definately furture-proof me for a while, or should I wait a few years and see what comes down the pipe?
