New radio vs older radio?
manichalo
anyone notice that older radios usually sound better then newer ones, they might not have the raw base but they seem better tuned, the sound quality just sounds better to me when they are mid 70's or older then the new ones. Like an older one speaker radio sounds better then a newer 'stereo' one with two speakers.
Well, two speakers are better than one, and much more is better than two.
In the past, we listened to radios more so it had to be better. Today, it takes last seat.:)
bikemig
I like old school looking mono radios and own a few. The Sangean WR 11 is a pretty good radio and looks good. Still two speakers are better; my favorite radio is the Cue Radio Model R1 stereo system.
No, never noticed it at all, because it simply isn't the case. Quality components are quality components, so if you compare quality gear from days of old to quality now, you will find that appearances may have changed, but good sound hasn't.
Rickster71
Rickster71
anyone notice that older radios usually sound better then newer ones......... Like an older one speaker radio sounds better then a newer 'stereo' one with two speakers.
What you are experiencing may be more attributed to the Mono vs. Stereo signal and their respective differences.​
(Not to say there aren't good and bad receivers of both types.)
Mono vs. Stereo FM
Mono operation gives an FM signal the best range, generally adding 30% to the useable distance over which listeners can hear a broadcast signal clearly. For radio formats in which spoken word predominates, mono is often a better choice.
FM reception problems are magnified by stereo broadcasting because of the receiver's increased susceptibility to noise in the stereo mode. A stereo FM receiver has a noise admitting bandwidth of 53 kilohertz, compared to about 15 kilohertz for mono. Through the stereo decoder circuit, all the AM noise above 19 Khz demodulates back into the 15KHz audio spectrum. This amounts to about an 11dB increase of noise intensity.
In addition, a left or right signal modulates the main and sub carriers just 45 percent each. This means that the recovered main and subcarrier signals are noisier than a mono signal by 6.9dB. When these are dematrixed, the net resulting noise is the RMS sum of the left and right channel noise that equals 1.4 times 6.9 or 9.8dB. The total net stereo reception noise is therefore 9.8dB + 11dB = 20.8dB worse than mono reception.
In a good receiver that is fully quieted, the stereo noise will be sufficiently low. However, even the slightest reception problems that produce noise or distortion will be exaggerated on a stereo receiver -- 21dB more than what's heard from a mono receiver. Manufacturers recognize this problem, and include a mono switch on their stereo tuners so listeners can tame troublesome FM stations.
markw
Rick makes an excellent point. A mono FM signal will always sound cleaner than a stereo signal.
But, some older radios in decent sized, resonant cabinets can have a "woody, mellow" sound that can be quite beguiling on some music.
On the other hand, I ave a Cambridge Sond works Model 88 (circa 1998) table radio that, while stereo, can sound amazing, particularly when I hit the mono button for marginal stations. Cleans up any signal instantly and the "tone" is surprising for two inch speakers (with a four inch subwoofer). ...and it fits easily on my nightstand.
