New LG30 hooked up directly to cable (no box) bad lip sync problem: anything I can do
N
Nexsen
If you are using digital audio (s/pdfi coax or optical Toslink)
outputs there are three products made to correct lip-sync in home
cinemas. They all allow the user to delay the digital audio while
viewing to achieve perfect lip-sync with no image disruption. They
are made by Alchemy2, Felston and Primare. I have the Felston DD740
and it works great. It costs $249 and amazingly has more features
than the other two which are about $399 and $499 unless you need RS232
control. They all have IR remote control but the ALchemy2 and primare
also have RS232 control. The Felston DD740 has 4 inputs and so does
the ALchemy DDL4 and D,DaD ($449 and $499) but the Primare only has 2
inputs. The Felston DD740 also has a fine adjustment mode with 1/3
the step size as the others and it also has more presets (9 per input)
plus numeric delay entry which the others don't have. That makes it
possible for a macro to totally control the DD740 with no dependence
upon recalling presets which is required of the others as well as the two
earlier Felston models (DD340 and DD540) when using programmable IR
remotes.
