Paisaab said:
Projector- need help badly here- BenQ DLP or the Yamaha LCD?
Read this article about the benefits of
LCD vs DLP first.
In regards to the projector…I would rather think in terms of longevity. If the projector lamp last 3000 hours, and you watch/use the projector say 10 hrs per week, then you will get approximately 4 years and 9 months use before the lamp will need to be replaced (unless it fails earlier of course). At the rate that the technology is advancing, compared to the price of the lamp, you would need to pay about 25% to 30% of the initial cost of the projector to replace the lamp, thus, you could upgrade at a relatively modest cost and get the latest and greatest rather than buying the flagship, top end model today. (This assumes you consider say a Sanyo PLV-Z3, Panasonic AE700, Epson “powerlite” TW 200+, et al…also note that the new models have just been released, so in the coming months, reviews should be available). The benefit is that rather than having to stay fixed with 5 year old technology, you could stay relatively current. Also the initial set-up cost will not be as high.
When you are not making an A/B comparison, it’s amazing how you will become comfortable with the picture you are watching. Same goes for DLP projectors.
I am told that LCD projectors have a bad "screen door" effect, not seen on DLP models
Screen door is not a major issue these days on either of the technologies, unless you sit within 1 to 2 feet from the screen!
I have included a picture I took of the SDE... not how close you need to be to the screen to see it (Shrek's right hand fingers). If you look closely, you can see the shadow of the lens on the right. The other two pictures are with the flash going off (washed out colors); the other with the room dark. Sitting about 12 feet away, image size is 110”,
Screen- buy a screen or DIY with plywood and Goo?
Then read this about
screens …please look around at some of the other articles for more info. I would recommend buying a screen IMHO.
Also, re upscaling- shoudl I try to do it with/via the receiver or the projector...I see that some projectors have 1080p, but not sure if they upconvert signals or not. Primary signal feed will be DVD and HDTV, so need 2 inputs (most projectors seem to have only 1).....verrry confused. Or should I get a separate scaler???
Any input will be appreciated. Thanks a lot. Cheers!
Paisaab
Now for the scaling…firstly assess how the projectors onboard scaler works, it maybe more than satisfactory, rather than increasing your set-up cost for an add on scaler. If the projectors onboard scaler works well, I think you should be able to do the video switching functions of the Denon as you should have two inputs to one output. (I haven’t seen the manual for it yet, so I am making an assumption). Otherwise I would consider an outboard scaler - this would also probably solve your input problem as all your video sources would go to the scaler first, then to your projector.
As for the rest of your selection, go for what sounds best to you...so far so good...I hope this points you in the right direction.
Cheers...
Dapper Dan...
