New Home Prewired- I might just be screwed...
Adamn
New Home "prewired". Unable to get sound with TV!!
*Cables Terminate on opposite wall of TV (about 20' apart).
*I have successfully connected my TV with component cables (prewired) to my Dish Network Receiver.
*Unable to get any sound to coordinate with my TV.
*Trying to integrate audio receiver/DVD/CD home theater setup. I am able to produce sound from speakers, but only when using the radio/CD player (can never get the TV to work with the speakers).
I have tried plugging an HDMI cable into the audio receiver and the dish receiver, but that obviously did not work... Will I have to fish more cable? suggestions? Please help!!
Bryce_H
Bryce_H
New Home? Go back to your builder and have them fix the problem. They dorked up my living room pre-wire and I had them redo it.
Why di you connect the Dish receiver to the TV? What you need to do is make video and audio connections to your receiver, and then make the connection to the TV from the receiver. If your units have HDCP compliant HDMI ports that would be the best connection.
