NEw H31 and graywolf 92 inch up and running...couple of questions
tones
Hey guys,
I got my H31 and 92 inch Groywolf up and running today....the first thing that impressed me was the Graywolf screen. After all the horror stories I heard about damaged goods I was pleasantly surprised to not find one nick in the casing or the screen....no waves or anything.
So I mounted the screen took a read through the H31 manual and decided to fire it up....it looked pretty good even without any calibration. This is my first projector so my "wow" factor doesn't mean too much...
One thing I am confused with is that I have the H31 temporarily on my low coffee table.but for some reason the entire picture is tilted down to the right...with the elavator foot down and using the tilt adjustment there is no way to counteract this without sticking something under the back right edge of the projector to boost it up.....this does not seem right.....am I missing something?
I am also wondering if someone could recommend some of their calibration settings that have worked for them to bring out the best picture and to allow this great projector to reach its full potential. I should be getting the Avia calibration tool tomorrow but knowing some good settings to get a jump start would be great. I am currently using a component connnection until my DIV cable arrives.
Also I have a Sony STR-DE597 Receiver with 2 components in and 1 component out. I have a component cable going from my DVD player to the Sony and one from my HD box to the Sony....I then connected the Component out port on the Sony to my H31 projector....for some reason the H31 does not pick up a signal...I had to take my component from the DVD player and connect it directly to the H31 to get it to work.
Thanks guys....glad to be part of the club....
tones
