New Guy needs advice on best universal remote
I
illuminati
I have been looking for a universal remote in the $100-$150 price range. I'm thinking about the X10 iconRemote because I like the favorite channel surf feature. Does anyone have any experience with it? Any other recommendations?
www.x10iconremote.com
I have a TV, DVD, Receiver, and DVR.
MDS
I don't have any experience with the X-10 remote but from the picture I would say the button layout is terrible.
IMO, the best remote in the $100-$125 price range is the Home Theater Master MX-350. You could also get the RF-20 + RF Blaster for the same price at Amazon. There are subtle differences between the MX-350 and RF-20 but the RF-20 would suit most people.
If you like 'favorite channel' type features, both of those remotes allow 40 favorites and each favorite can actually be a macro that can do anything you want, although if you actually use it for favorites the macro would just send the channel number to change to that channel.
I
illuminati
Thanks, I'll look into those, too. What don't you like about the button layout on the iconRemote? (I don't know too much about that kind of stuff.)
MDS
Keep in mind that I have been using HTM remotes for years after trying all different kinds of remotes and they are my personal preference but having said that, here are some things that I don't like about the X10 just by looking at it:
- Cursor buttons (left, right, up, down, select) near the top of the remote. Without holding it in your hand you can't tell if the natural balance point of the remote will be such that when you hold it your thumb naturally falls over the cursor pad but it may be alright. You end up using those buttons a lot.
- Transport controls (rew, ffwd, play, etc) at the bottom of the remote. That's a problem if you need to use them in combination with the cursor controls - especially for things like OnDemand where you can use those controls just like on a dvd player to control the movie. It's a problem if you have to constantly reposition the remote in your hand to move from the cursor controls to the transport controls and back.
- Too many dual function buttons. All the buttons that have red or green writing above them have multiple functions. Without reading the manual I can't tell if you have to press a certain 'mode' button or they automatically switch functions per mode. This may not sound like a problem but it can be - case in point the old HTM MX-500 remote: The Rew button also functioned as 'Guide' for cable. So you couldn't use the Rew button when watching OnDemand on cable because it activates the guide.
- The beautiful LCD screen appears to have no function other than storing 'favorites'. The above problem with Rew vs Guide could be solved on the HTM remote by programming either one to one of the LCD buttons. Doesn't appear that you can do that with the X10.
- It is a 'standard' remote in the sense that every button is labeled so you have no way to store A/V specific commands that you will find on a typical receiver - like 'Late Night'. I don't see any generic buttons that can be used for any command you like and even if it did have them they are not the best solution anyway.
That remote is a souped up All-For-One 8811. Those kinds of remotes have dedicated buttons labeled L1-L4 to which you can learn any command. But they are few and its hard to remember that you programmed 'Late Night' to L1 and 'Surr' (to change surround modes) to L2 for example. It's much nicer to be able to label a button anyway you want and also to be able to program any command to any button you want to suit your own tastes for layout.
The HTM and Harmony remotes are much more flexible and IMO are a better choice. I prefer HTM over Harmony but that's just me and based on having experience with HTM.
I
illuminati
Thanks for the info. You have put a lot of thought into this:).
You make some valid points about the button placement. I'll keep that in mind as I wade through this neverending sea of universal remotes.
I found thie manual online:
http://www.x10.com/pdfs/kbase_iconr_manual.pdf
On the bottom of page 21, it looks like all of the keys next to the LCD are both learnanble and renameable. So that's good. But I'll definately look for remotes that can learn (so I can add specific functions) and that I can rename the learned keys.
B.L. Zebub
I have been using the iconRemote for a couple of weeks now. I like it a lot. It's not perfect on the button layout, but I have yet to come accross a remote that has every button right where I would put them. That said, it was really easy to set up. It only took me a couple of minutes. And the favorite channel logo feature is really cool.
johnb554
johnb554
Not sure if this is at all useful information to you or not but....
As a universal remote, i use my Pocket PC/Palm Pilot.
I didnt have another use for it and it was just collecting dust but one day, i came across some software for it that turns it into a compleatly customisealbe and trainable remote. Never had problems with it.
If you have a PDA that you dont really use, you should give it a try.
John
jcPanny
jcPanny
Urc 300
I bought the HTM URC-300 remote w/ RF basestation for just over $100. The URC-200 is very similar to the MX-350 model and the URC-300 adds a touch screen LCD and can control more devices.
It has a favorite channels menu/function but I haven't used it. The macros and RF are great for pressing a single button to turn on the Receiver and source and adjust the volume from anywhere in the house.
darien87
darien87
I don't have experience with the remote that you're referring to, but I do have the Harmony 880. I think I got it on eBay for about $130. It works great. I took a little while to set up and get everything working correctly. But once you set it up, it's awesome. I like the activity based macros and the online programming.
Bryce_H
Bryce_H
Another vote for the Harmony. I have a 676 and love the activity buttons.
BMXTRIX
BMXTRIX
Just get a Crestron system installed and call it a day. ;)
JacksonStone
To all those that were interested in the iconRemote, let me set your mind at ease. It's a good product. I understand your concerns about the button layout. Don't worry, it feels natural to use the directional pad. Unfortunately, I'm not a big DVR user, so I couldn't tell you whether the transport buttons were intuitive or not. Also, the buttons on either side of the display screen are programmable, so even if the transport buttons are a bit of a nuisance, you can always map those key functions to the softkeys.
W
Walter77
iconremote
actually, i too purchased one of the iconremotes from x-10 and am quite pleased with how its performing. i was worried that i wouldn't be able to use it with my 360 but was able to program it with no problems. i'm running a RCA DLP bigscreen and it programmed right away, along with being able to get my LG stereo system working with no probs....
i have to add my 2 cents here too and say (although i'm not worried about the ergonomics) the remote was able to pick up all my equipment with relative ease. it's a good remote....
I
illuminati
I ended up buying an iconRemote, too. I've only had it for about a week, but I am pretty happy with it.
The favorite channel logos are a cool feature. Now I don't have to surf through a bunch of crap to get to the few decent channels on TV.
Macklemore
Did you notice the "mystery port" near the batteries? Have any idea what that's for?
