MacManNM said:
If you can post some pics and dimensions, I’m sure we can get this figured out. Do you have any type of equipment to make some measurements of the electrical properties of the crossovers? There are 2 choices here, you can try and just upgrade your drivers and use the existing crossovers, or you can design a new unit around the enclosure, which would include new crossovers and drivers.
HI,
Thanks for everyone's input, it's a big help.
I do have a multi-meter to make measurements.
Your idea sounds good; about changing drivers first.
My drivers have numbers stamped on them, no manufacturer.
I've been told there is a 'speaker list' to cross reference, to find out who makes them.
Do you know anything about that?
The other issue is, I don't want to replace the drivers with equivalents.
I'd like to really improve on them.
So, how will I know what drivers to pick, and how they should compliment each other?
Would my next step be to measure internal volume.
Then find software to tailor a crossover?
My other question, how do I match the drivers to the crossover?
Sorry for so many questions, this is the point where I get bogged down.
What first, chicken, egg, speaker, crossover?
THANKS Everyone!
