I don’t have a TV hooked up yet, can I still set it up to play Alexa? HOW?
Good4it Audioholic Chief Jan 23, 2019 #1 I don’t have a TV hooked up yet, can I still set it up to play Alexa? HOW?
lovinthehd Audioholic Jedi Jan 23, 2019 #2 Can't help you with the Alexa thing, but to maybe start you here. Congrats on changing from the Yamaha you were so unhappy with?
Good4it Audioholic Chief Jan 24, 2019 #3 I went to the link, it told me how with a tv but not without. I also called the Denon support # twice and both couldn’t help. Sounds like I better get a tv. Thanks for the link/good wishes.
lovinthehd Audioholic Jedi Jan 24, 2019 #4 Good luck, might want to post up specific questions/issues. Somebody's bound to want to talk to devices, I'm just not one of them.
lovinthehd Audioholic Jedi Jan 24, 2019 #5 Good4it said: I went to the link, it told me how with a tv but not without. I also called the Denon support # twice and both couldn’t help. Sounds like I better get a tv. Thanks for the link/good wishes. Click to expand... You haven't been using a tv all along with the Yamaha and now the Denon?
everettT Audioholic Spartan Jan 24, 2019 #6 You need some kind of display to setup any modern avr. Computer monitor etc.
lovinthehd Audioholic Jedi Jan 24, 2019 #7 everettT said: You need some kind of display to setup any modern avr. Computer monitor etc. Click to expand... Yep or at least it makes it immensely easier than trying to use the avr panel alone (especially those port hole Marantz things)
Good4it Audioholic Chief Jan 24, 2019 #8 lovinthehd said: You haven't been using a tv all along with the Yamaha and now the Denon? Click to expand... Have a 65” Sony with the Yamaha but it’s wall mounted in the den and the Denon is in the bedroom and no tv in there. Bedrooms are for sleeping.
everettT Audioholic Spartan Jan 24, 2019 #9 Good4it said: Have a 65” Sony with the Yamaha but it’s wall mounted in the den and the Denon is in the bedroom and no tv in there. Bedrooms are for sleeping. Click to expand... And music
everettT Audioholic Spartan Jan 24, 2019 #10 https://www.amazon.com/RAAYOO-Definition-Monitor-Display-Optional/dp/B074P4L9XK/ref=mp_s_a_1_4?ie=UTF8&qid=1548378396&sr=8-4&pi=AC_SX236_SY340_FMwebp_QL65&keywords=5"+monitor&dpPl=1&dpID=41R8swjkqUL&ref=plSrch
everettT Audioholic Spartan Jan 24, 2019 #12 Good4it said: Denon said it had to be HDMI. But nice try. Click to expand... https://denon.custhelp.com/app/answers/detail/a_id/279/~/no-osd-/-gui-output-to-my-tv Not sure but legacy connections usually work for osd. I can check when we go up to the other house, but I'm sure someone can confirm quicker
lovinthehd Audioholic Jedi Jan 25, 2019 #13 Good4it said: Have a 65” Sony with the Yamaha but it’s wall mounted in the den and the Denon is in the bedroom and no tv in there. Bedrooms are for sleeping. Click to expand... I love watching movies and tv in bed....do you have multich audio at least?
Good4it Audioholic Chief Jan 25, 2019 #14 everettT said: https://denon.custhelp.com/app/answers/detail/a_id/279/~/no-osd-/-gui-output-to-my-tv Not sure but legacy connections usually work for osd. I can check when we go up to the other house, but I'm sure someone can confirm quicker Click to expand... Ordered 1, thanks. Only way too know for sure is try.
Good4it Audioholic Chief Jan 25, 2019 #15 lovinthehd said: I love watching movies and tv in bed....do you have multich audio at least? Click to expand... Only 2 speakers so far.
highfigh Seriously, I have no life. Jan 25, 2019 #16 Good4it said: I don’t have a TV hooked up yet, can I still set it up to play Alexa? HOW? Click to expand... The number or existence of TV should make no difference. You can use Bluetooth to send from an Echo or receive BT from the AVR. Exactly, what are you trying to do? Control the equipment?
Good4it Audioholic Chief Jan 25, 2019 #17 highfigh said: xactly, what are you trying to do? Control the equipment Click to expand... I’m trying to hookup to the Wifi using the front display. It’s not easy. I canceled the 5” monitor because it was so small. I have Alexa working.
Good4it Audioholic Chief Jan 25, 2019 #18 SUCCESS! Caller Denon support a third time and got someone who knew about my unit. He talked me through it and got me online without a TV. . He was knowledgeable and patient.
