I am about 3 months from completion on a new house and I need to figure out how I am going to set up the sound and video throughout the house. Any help would be greatly appreciated.
I have been debating whether this is something I can handle on my own and am not sure whether I should just give up and just go through the phone book and pay somebody to come in and get me setup. But I figure I'll have to buy everything at retail from a pro and I do have a decent handle on what I want, so I'm torn.
I will be building a home theater in a room that is designed as a formal living room (for resale value) so the layout is a bit unorthodox. I am leaning toward going with a Sony VPL VW12HT but if anyone has a good reason to consider a DLP in similar price range, I'm open to advice. The reason it is unorthodox is that you will walk into the room through a four foot "hallway" because of two closets on either side of the entrance to the room, one for coats, the other for components. You will basically be staring at the back of a couch when you walk in with a retractable screen across the room from you (leaning toward Stewart FireHawk, but again open to advice) so the rear center of a 6.1 will have to be in the ceiling since there is no wall there. For this room I have two Klipsch KPS 300's for the front right and left, and they should provide sufficient bass without a subwoofer (right?) but I will need a center channel and all three rear speakers. The left and right aren't as important to me since I assume they will be installed on the walls (not in them, not enough room in my walls for anything decent) but the center will be in ceiling and will be much easier to do during construction than after, obviously. Any advice on all three would rears and a center that would go well with my 300's would be appreciated. Room is 16 long by 14 wide (not counting little entrance hallway), and all ceilings in house are 10 feet.
I'm going to have a kitchen/great room that is 44 feet long by 15 feet wide. I'm going to put a pair of bookshelf speakers at one end with some good bass (suggestions?) and two pair of ceiling speakers through out the rest of the room (again, not enough room for in walls and no place for towers or stand mounted speakers because of doors, windows, cabinets, etc). I've been looking at Phase CI 7.3's, Sonance Ellipse 1.0 LCR's, PSB M6.1R's, Posh 928's (no idea where to even buy those), Atlantic Technology IWTS-8CMS, and Klipsch R 5800 C. The more I read, the less clue I have. Anyone recommend any of these from experience? I have music on most hours of the day, but I am not an audiophile. As long as the speakers can be pretty loud, with good bass and reasonably clear high end, I'm happy. Basically loud and good, but doesn't have to be specatacular (which is good since they are ceiling speakers after all). Any help would be great.
Lastly, any advice on good (but not specatacular) components to run all this from--i.e, receiver, amp. And is there a way to play music from a computer that is better than the crappy speaker outputs standard on any computer? To anyone with advice, thank you.
Ben
