I think you missed my point. The idea of the isolation is to keep it quieter INSIDE the room and prevent noises from outside from getting in and raising the ambient noise floor. Even though your 3 walls are concrete and dirt, sound can flank around through a weak wall structure and up through the floor into the rest of the house (though this may not be your concern as you stated).
I have no idea what Kinetics is proposing so I can't comment on what the package is, if it's a viable, reasonably priced solution, etc. Personally, in your case, if sound leaking OUT isn't a concern, I'd do the following:
- RSIC-1 clips on the ceiling with hat channel.
- Double drywall with Green Glue on walls and ceiling
- No need to float a floor though you can if you want.
- Seal under the wall/floor intersection with sill seal and caulk the edges.
- Fully insulate all cavities (walls backed up to concrete, interior walls, and ceiling cavity above)
This is a reasonably priced way to get very good isolation, a very predictable starting point for treating the interior of the room, etc. - without giving up a ton of space or money.
Bryan
