Neutrik Interconnects
photoeye
Hi,
has anyone used the NEUTRIK NF2CB?
not sure if I'm doing something wrong but the barrel does
not seem to screw all the way in once the cable has been soldered.
These are expensive compared to the other ones. I'm not sure how
long the spring loaded design will last, if it's actually better design or not.
I'm using it with the mogami 2534 cable. What other rca plugs provide bang for the buck?
thx.
I have some cables made with them and all I can say is two of the center pins broke off... Not the quality I expected from them.
jcrobso
NYS352G are the ones I have used.
Never had a problem, they cost a lot less than the NF2CB/2. John
