doggitz
Hello! I am new to the forum.
I do a fair bit of streaming and chanced upon some discussion/ads regarding network cables (e.g. CAT 5/6, etc). I have seen some of Gene's videos on digital cables and believe that he makes sense. That said, there are network cables out there for thousands of dollars. That doesn't make sense to me. The network signal needs to come to the house, through my modem, router, cable in the walls, and finally to my player. I do not see how spending a lot of money on a boutique network cable can make any difference at all. The ads seem to have typical subjective claims, without any objective data..
Is there a consensus of opinion? I would appreciate your thoughts.
Thanks
Fred
Welcome to AH. :)
Follow Gene's suggestions.
You certainly don't need expensive cables. But it sells, so they stay in business. ;)
You are correct about the cables in your house and to the router. Is your streaming working? If your run is short to the router that you have control over, Cat 5e is enough. If you don't have that cable and need to get one, get Cat6, should not be much more.
Enjoy.
Those proposing the multi thousand dollar cables are called charlatans, and peddle snake oil. Not much to it other than bullshit.
dolynick
Unless you're network or Internet service is capable of passing through more that 2.5 Gbps, then you're fine with good old Cat 5e. Any reasonable quality cable will do (Amazon Basics has a nice selection). If you want to go up to 10 Gbps, then you need to look at Cat 6e or better.
If Cat 6e is not dramatically more than the Cat 5e cable, then it's probably smart to go with the 6e just for future considerations
Unless you have a very high end motherboard or have invested into a 10G network card, it's probably not something you have to worry about right now. 10 Gbps switching gear is still expensive enough that it's not widespread as a standard for most home users yet either.
