Praxis
Hello All:
I know that this is mainly a hardware forum but if someone could help me with this particular software burning problem I would be grateful.
Through trial and error, I've found out that Nero has been the culprit in my experiencing distortion in some tracks with very high notes when I would burn to an audio disc. This would happen because I chose to check "normalize", and it doesn't look like there is anything that I can do with Nero to help eliminate this problem unless I choose not to "normalize" the burn. But, that is the feature I'm wanting.
Could someone tell me of a burn programme - freeware- that I could use that has an "equalizing" feature, for lack of a better term, (like Nero's "normalizing" burn option) that when I'm compiling a list from different albums/artists to burn to a single disc it will equalize them?
I know that there are probably several out there but if someone with experience in wanting the same option as I and discovering it could help out that would be great.
Thank you,
Praxis
Thank you,
Praxis
