Neo:6 no subwoofer??? help
G
Gadget
Just found the site and appears to be very helpful. Registered today but found no answers while searching this forum. Here's the deal:
Today I received my Polk PSW505 subwoofer and hooked it up. My System is as follows:
Sony STR-DE895
Klipsch RF-35's
Klipsch RC-35
Phillips DVP642 and a Toshiba 24" Flatscreen (unimportant but thought I would through it in anyway.)
Well I have been tinkering with all the settings trying to get it to my liking and I am very pleased with the sub so far, the sound is awesome and I have no complaints as of yet.
Here's my problem, I like the way the Neo:6 Music and Movies preset sound the best but when I switch to those, the sub doesnt play. If I go to A.F.D Auto, it works great but then the center channel does not play. Just the two fronts and the sub. Now, if I use some of the others such as the prologic presets, it just doesnt sound good and is really quiet.
What do I do to get the sub to work with Neo:6??? Please Help!
Thanks
G
Gadget
I seem to have figured out one of my problems... on the receiver when set to Neo:6 if the front speaker is set to large there will be no sub output. I had to set it to small and then the sub comes on.
Now another question, the sub hums when the receiver is turned OFF. What does this mean?
JoeE SP9
JoeE SP9
You may have a ground loop. Reverse the polarity of one AC plug. You may need to get a "cheater" 3 pin to 2 pin adaptor. Try reversing the polarity of the sub first. :cool:
G
Gadget
It only hums when the receiver is turned off.. I can have the receiver on and on a device thats not even hooked up and its quiet, but as soon as the receiver turns off it hums.
Could it have anything to do with the cable direction? I am running a Monster THX ULTRA 1000 and it didnt come with a directional arrow on it. If I flip that around would that possibly fix it? or have nothing to do with it.
