Again, very little info to get useful suggestions.
What is your budget?
What are the specs of the CV's? ie sensitivity, minimum power requirements.
Most avr's, other than the cheapest you can find, will have Blutooth and HDMI.
Your avr will need outputs to connect to an amp.
Why do you think you need an amp as well as an avr? Are the speakers that power hungry.
You need to do a lot more homework so you can ask questions that are answerable.
