Needed: small surrounds to be mounted on the ceiling ...
stuhoo
I am new to the forum.
I am planning on upgrading my current HT sound system and am looking for suggestions for a timbre-matched 5.1 or 6.1 setup.
I want musical front speakers, either towers or good bookshelves. I have space for a quality center speaker and sub. My problem is that I only have space for small surrounds which need to be mounted on the ceiling. I am having trouble finding a matched system that meets these requirements. Room dimensions are 16' X 18', with one open side. My budget is ~$1500-2000 for all speakers in the set.
I would appreciate any suggestions that the experts here may have.
-Stuart
AVRat
AVRat
How small is small? Would a small bookshelf using a bracket be acceptable? Or are in-ceilings an option?
sploo
Hi Stuart,
I have some small, but reasonably weighty surrounds (roughly 11lbs each). They're mounted on the side walls with a couple of inexpensive (<40USD) brackets.
These speakers were self-builds (from a purchased design) and seem to be heavier than many surrounds I've seen, so you should be able to get away with bracket mounting most small bookshelf type units.
RLA
RLA
Hello
That is a fairly large room and many small systems may not be capable of reproducing satisfactory listening levels.
If a small system is what you are after you may want to look at these
http://www.klipsch.com/product/product.aspx?cid=731
They are pretty dynamic little speakers and they have a built in stand that rotates 180 degrees for wall mounting
