Need your help to understand
K
Kishore0416
Hi All, hope you are doing fine.
Need a help here to understand some differences. So far my opinion is a good brand speakers sounds really well when we play music. I have seen this on paradigm, monitor audio and JBL.
When coming to home theatre experience. I havent seen much difference between these speakers.
Can you help me understand if my opinion is correct.
I am comparing these
Jbl :
135c
A120 bookshelves
A190 towers
Arena 6ic
Monitor audio:
Bronze 500 towers
Silver fx
Bronze c150
Pro 65 ceiling
These are paired with 4700h using a switch...
What differences can we observe in movie experience in these speakers
Verdinut
Verdinut
IMO, good speakers for music are also good for movies, if they can handle the dynamic range required with some action movies.
Ideally, you should be able to compare them with a musical source that you already like. If you can hear the two which would be used for the front left and right channels, in a hi-fi store with one or two of your preferred CDs, that would be the best situation. Speakers used for surround and Atmos duties are not as critical in a system. Also, If a store offers you the option to try and return them should you not appreciate their performance, that would be great.
