Need Tv Stand and speaker Can anyone suggest ?
jkk
Hi
I want to buy TV Stand and Speaker with great sound and base please suggest where can I buy it online ?
rojo
rojo
Hi jkk and welcome! Can you tell us a bit about yourself and your preferences? Are you in India? Do you intend to use this great sound for mostly music, mostly movies, or half and half? What type of music do you enjoy? What is your budget? Can you describe the room you'll be setting this new equipment in? Do you already have a receiver you intend to use, and which one? Can you think of any other details it might help us to know?
jkk
Yh man I am from India. I would like to use my speaker for both the purpose music and movies but I love rock music . Previously I was using creative speaker. But now i want to buy new one Upto 20 k.
rojo
rojo
I'm a blind man leading the blind here. Audioholics has active members representing North America and Europe pretty well, but I haven't seen many south Asians. If I were you, I'd also ask at a forum primarily serving India. Some search spidering lead me to Erodov. They seem to have some worthwhile opinions over there. I recommend registering there and posting a new thread. Be sure to let them know whether your budget is just for 2.1 speakers, or if you will also need a receiver or amplifier.
Having said that, this Swans 2.1 combo looks pretty promising. There won't be much of anything left for a TV stand, but you can really repurpose a bookshelf or anything for that, and buy a dedicated TV stand later if desired. With a limited budget, you'll be better off in the long run to squeeze as much of it into the audio system's performance as you can, then make it pretty later.
In any case, I hope you stick around, let us know what you get, and let us know how it sounds, how the wife approves, and show us pictures. :)
jkk
thanks for your suggestion!! ll let you know if if I get one.
