I am a newbie and need advice on speaker for a H/T system (music oriented)
I recently bought the Polk Audio RM7600 + PSW303 sub and
use the Yamaha RX-V800 to power the RM7600.
The speakers sound wonderful, but the RM7600 is a bit bulky and hard to
mount or put on stand, and the center speaker is too large to fit into the
cabinet. It fits above the TV but the color doesn't quite match.
(black glossy speaker over dull silver TV) Overall, my only conern on the
system is the size and the look.
My biggest sturggle is whether to return the RM7600. It sounds excellent
and I purchased it at a great price ($800 sat + sub, MSRP is $1500+) .
If I return it, is there anything smaller that sounds equal or better in
the same price range? Although the speakers are put in the living room as a
H/T system, they are used primarily for music listening (classical),
movie watching is only secondary.
My requirement is anything that sounds as good or better than
the RM7600 and is smaller.
Should I keep the RM7600? Great sound, great deal, but a bit bigger than
my taste.
I am also considering a Home theather in a box (those including receiver)
solution, with or without DVD. Is there any decent HTIB out there?
I tried the Onkyo HT-S770 and the charity was week at high frequency. I like
clean and crisp treble. Appreciate any suggestion.
