I am a newbie for the most part and having trouble deciphering the cryptic language the instructions/setup guides come in.
I am trying to optomize the performance of my receiver and blue ray player but not exactly sure what I am switching around and why...
for example~ Bitstream or BD video Secondary or PCM. As of now I set everything to be sent out as bitstream... should I go back to the other option...PCM?
How about component video resolution? Right now it is factory set at 480i and can go up to 1080i.
On the reciever for HDMI resolution it is factory pre-set at "through" which "does not upscale any analaog video signals" . My options are 480/576P which upscales to either or... 1080i, 1080p or 720p which upscales to either or....
Can the yamaha process signals with sampling frequencies of 96 kHz or should I scale it back to 48kHz? This is an option under the PCM Down Conversion application. Does it even matter?
I don't even have a Yamaha. However, I can tell you pretty much any receiver (with a DTS logo) made in the last 3 (really 5) years will do 96 kHz. Regular DTS (not just DTS-HD MA and DTS-HD HR) will do 96 kHz/24-bit audio. DTS-HD HR/HR, Dolby Digital Plus, Dolby TrueHD and DVD-Audio will do up to 192 kHz/24-bit audio (albeit two channel). SACD? Well, that's a different animal.
Mtbound, what Blu-Ray player do you have? n/m--I see BD30. Yes, set it to bitstream, as it doesn't internally decode. Who is your multichannel provider (Comcast, Dish, DirectTV, Time Warner Cable, Cox, etc.)?
J. Grimmerink is right. That Panny plasma will likely do leagues better upscaling than your receiver.
