This is some info about my amp:
Technical details:
• Power max.: 2x 240 Watt max. on 8 Ohm
• Power rms: 2x 106 Watt on 8 Ohm
• Delay 5,6 µs
• Impedance 4-8 Ohm
• Frequency range 20Hz-25kHz
• Signal-to-noise ratio 80dB
• Distortion factor < 0.3%
• Protection circuit (short circuit proof)
• Weight: 7,5 kg
• dimensions: 480x250x100 mm (WxDxH)
• security switch
Its one of these:
cgi.ebay.co.uk/480-W-DJ-PA-POWER-MUSICAL-NEW-AMPLIFIER-IMPACT-240-bl_W0QQitemZ290288688726QQcmdZViewItemQQimsxZ20090112?IMSfp=TL090112127003r21731
And the speakers are big and old that were made in Russia
I do not have the specs of those but I know they are 8 ohm. The only thing I know is that they sounded a lot louder with another (old russian) amplifier.
So when I am playing live the LED VU meter on the amplifier stays pretty high (never goes lower than 3 top LEDs while playing). I wonder if it can be harmful to the amp or the speakers.
Thanks for the info!
