I know bi-amping will not give me more power, its meant for more adjustability. I am going to be building set of 2 ways using seas or scan speak. In doing my research I found most set ups were using external amps.That's what led me to think a separate amp was the way to go. I come from the car audio world (not the boom boom ,but the SQ side) so I am so use to amping, and going active or bi-amping. I just do not want to spend a few weeks building a set of speakers and find out my rec. power is not what they really want. The drivers I want to use have good sensitivity and I want to be able to drive them to there potential. Maybe I am looking into it too much. That's what happens when you come from the $4000+ car stereo world..
With car audio, the ratings on head units are typically inflated by giving you the power output with massive amounts of distortion, and likely not over the entire frequency spectrum. With home audio, typically (though not always) one sees ratings into low levels of distortion from 20-20kHz, and so those ratings can generally be trusted, into the rated impedances. One thing that upsets some people, though, is the fact that most surround receivers cannot deliver that power to all channels simultaneously, but that is not a real problem for reasons explained at:
The All Channels Driven Amplifier Test Controversy | Audioholics
The All Channels Driven (ACD) Amplifier Test | Audioholics
Now, of course, there are ways in which manufacturers can and do manipulate ratings:
AV Receiver and Amplifier Power Ratings Trends: How and Why Wattage Ratings are Manipulated | Audioholics
But it does not compare with the ridiculousness found in car audio.
When comparing power ratings, one should compare over the same set of frequencies, with the same impedance, with the same (or very similar) levels of distortion, both continuous ("peak" power is generally outrageous inflation of the numbers). Otherwise, the ratings simply cannot be directly compared at all, as they are not discussing the same thing at all. Unfortunately, the law does not require more honesty in such things than it does, but if one takes the precaution of not trusting a power rating if it it does not specify duration (should be continuous), impedance, frequency range, and distortion, and then only comparing the number with other numbers with the same stipulations (or, in the case of distortion, nearly the same), then one will be fine.
Edited to add:
Here is a link to a car stereo from a respectable brand (I use a Pioneer car stereo myself):
DEH-X9600BHS - NEW! - CD Receiver with Full-Dot LCD Display, MIXTRAX, Bluetooth®, HD Radio™ Tuner, and SiriusXM Ready | Pioneer Electronics USA
If you click on the specifications tab, and then on the audio tab, you will see that they claim 50 watts x 4. However, they do not there specify what frequencies are covered, what impedance of speaker, what level of distortion, or whether that is continuous or some sort of "peak" power,
SO IT IS COMPLETELY USELESS AND WITHOUT REAL MEANING.
Here is the manual with the real specifications on page 33:
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-X9600BHS_OwnersManual080713.pdf
There we see that the 50 watts is peak. They rate it at 22 watts continuous. Into 4 ohms. But that is not all. It is rated from 50-15kHz. Meaning, if they rated it from 20-20kHz, all that you want, it would be a lower number. And then they say it is with 5% THD. That is higher distortion than you want to hear, so it is even less for a well rated amplifier. In other words, the difference between this and an amplifier rated at 50 watts RMS continuous into 4 ohms, 20-20kHz, with <0.1% THD is quite dramatic. That is because the "50" in each case is referring to a completely different thing (peak vs. continuous, limited frequency vs. full frequency, high distortion vs. low distortion).
I would guess (and I freely admit, this is a
guess; to
know, it would have to be
measured) that the Pioneer head unit is really more like a 10 watt continuous per channel amplifier, if rated over the entire frequency spectrum and at a low level of distortion.
One more thing: Pioneer is not exceptional in this regard. It is standard practice for car stereo makers to give ridiculous ratings for head units. So I am not picking on Pioneer in this; they are a convenient example, selected by me,
because I would recommend buying a Pioneer for a car stereo. If we were looking at a bad brand, it would not give us a good example of the ridiculousness of car stereo ratings, as one might think that the idea only applies to bad brands.
