This question is one of the most popular questions. There are many threads on this subject.
It seems DM, Yamaha, and Anthem are the 3 big AVR heavyweights these days. I think a lot of newbies would love to get some perspective on these three brands. What are their pros and cons? If you have owned all three brands of AVR, your opinions would be greatly appreciated. If you have at...
forums.audioholics.com
My bet is that it will come down to Denon vs Yamaha.
Whatever we own and think is best for us, we will recommend to you.
There are pros and cons to all.
It comes down to what's salient to you.
1. Auto Room Correction? Have you experimented with any type of Auto Room Correction software? Some love, some hate. Some swear by it put 100% of their buying decision into Auto Room Correction. Some couldn't care less and would put 0.0% of their decision into any auto room correction. You're not going to find one unanimous answer.
I haven’t experimented with any auto room correction software before. I will definitely take your guys opinions however and have read many people say that Audyssey xt32 is better than ypao.
2. Manual EQ. This one is easier. But again, some want manual EQ, some don't. There are 2 types of Manual EQ - Parametric EQ and Graphic EQ. Parametric EQ is the best one. High-end pre-pros (Bryston, ATI, Classe, Anthem, etc.) will have Parametric EQ, not Graphic EQ. Yamaha uses the Parametric EQ for every speaker and subwoofer. Even the $7,500 Denon AVP-A1HD used the Graphic EQ. And even then it was only for the Main Front L/R speakers, not for every speaker and sub.
No experience here either. Not sure I would be overly interested in tweaking every eq setting per speaker.
3. Reliability. Yamaha might be the most reliable. Time will tell.
definitely a consideration of mine since I don’t expect to replace it anytime soon.
4. Service. Yamaha will pay for shipping both ways for both new and refurbished warranties. Might be an issue for many people, depending on the type of repair.
that’s good to know thanks. I have an old onkyo nr807 where the hdmi board went out and I know they replaced it complexly free of charge even though it was out of warr
5. Repair centers. I hate Panurgy, which is the authorized repairer for Denon/Marantz. I think DM should find somebody better. They were not able to repair a few of my Denon's I've owned in the past, including a $7,500 Pre-pro. One time I got back a Denon AVR from Panurgy repair and the AVR was still broken and a big smoke came out of it. I think too many bad experiences with Panurgy for me.
no experience dealing with Panurgy either, but thank you for sharing your experience. Definitely more mindful of what kind of support I can expect depending on the brand of receiver.
6. Compatibility. Some people have had issues with HDMI compatibility with some equipment. Yamaha might be better here. But everyone's experience may be different.
I don’t have anything really complicated to plug in here, a ps4, fire tv,
7. Apps and Streaming. By far, the Yamaha AV Controller WiFi Remote Control app is the best I've seen. It works extremely well and just perfect for me. The MusicCast and AirPlay streaming apps also worked perfectly for me. In contrast, the Denon Remote app worked about 50% of the time for me. Maybe less.
i’ve read others say the same thing about the Yamaha app compared to other brands. Definitely a strong consideration for me.
Everyone will have a different experience.
So I think you might want to list the most important points for you.
