Double Down
Hopefully I am putting this in the correct area, if not, let me know or someone move it.
This is my first attempt at really putting together a decent system and I would like help from people who know what they are doing.
I would like to tell you what I have and what I intend to get and then, if you could, help me understand how to correctly set everything up so I am maximizing and using everything the best it should be used.
Receiver - Onkyo TS-SR500 (connections images attached)
http://www.onkyousa.com/model.cfm?m=TX-SR500&p=f&class=Receiver
DVD player - OPPO DV-981HD 1080p HD Up-Converting Universal w/HDMI
http://www.oppodigital.com/dv981hd/dv981hd_index.html
Speakers - 5.1 Harmon/Kardon's
Tivo - regular model that comes with DirectTV
TV - DirectTV (no HDTV yet)
Projector - Probably going with Panasonic PT-AX100U
Game system - PS2
Okay, with all this in mind, as I mentioned before, I really am new to the world of projectors and I want to setup my system, using the receiver and other components the best way possible so whatever advice would be helpful on how to make the connections on everything.
The projector would sit on a mantel on my back wall(see picture) and project across the room approx 12' away on our big white wall painted with either screen goo or Do It Yourself screen paint (unless someone has a much better suggestion). We do have some ambient light that comes into the room but we can block about 80% of it with our drapes. The max screen width would be 84", which would be 96" diagonal at the 12' throw.
To make things easier, I've attached a rough drawing of what the current setup of the apt looks like. Plus I've attached real pictures to give you an idea of what I am working with. Of course pictures don't do everything justice but they help. Also, disregard the mess, just got married and we are cleaning up a ton of stuff and reorganizing things.
On the wall where the TV and components are now I have a little over 7' of width to work with. The fire detector will be removed and put somewhere better. On the picture with the blue couch and marble mantle was where I though to put the projector. But if I put it there, wouldn't I have to put the components close to it so I am not running like 25' of cable from the DVD player and to the receiver?
In addition, I was going to take down the top part of the black metal stand so that only the TV was left and rearrange things so that the TV stayed there and the projector image was viewed about 2' higher than the TV.
Couple things I/we had wondered:
1. Can we keep our 32" TV and use that solely for TV and then use the projector for just movies and games with our current components and connections? Or would you recommend watching TV on the projector (mainly at night anyway) even though we don't have HDTV?
2. Do we need to have all the components as close as possible to the projector so we aren't running expensive long cables around the room?
I know this is long, but I really want to do this right so thank you in advance.
Thank you,
Chris
Game system - PS2
Thank you,
Chris
