need some advice......
tcarcio
Hi guy's, I have a question. I have a Benq PE7800 that I have had now for 4 years and it still works fine but I got my hands on a PE8700 which is basically the same PJ except it has a little higher resolution. It doesn't power up and I don't know why but is there a way for me to change something out from the 8700 into the 7800 and bring up the res on the 7800? Or would it be better to try and find out what is wrong with the 8700 and maybe swap out a pert from the 7800. Now keep in mind I am not big on fixing electronics at all so if it is something that is basically a plug and play thing then fine but if not please tell me not to try it. Thanks guy's.........http://www.benq.us/support/downloads...fspecs%2epdf
annunaki
annunaki
Moderator
You would probably be better off placing this in the projector forum. Mostly speakers & such here, though there are a few DIY videophiles around.
tcarcio
Your right, Do you want to move it or should I just repost it? Thanks.:)
