csmith15
I am new to the whole a/v world, but I recently got a new HD tv, and am wanting to get a good HT system for it. The problem is I need to eliminate the rear speakers, so I am looking for a good 2 or 3 speaker system. I found the Bose 3-2-1 series 2 for $750, but I notice that alot of people don't reccomend Bose. I was wondering if that was a good deal or if there was something that would sound better for the same price or less. Any help would be greatly appreciated. Thanks.
jcPanny
jcPanny
HT system
If you do some reading on the forum, I think you will find several better performing options than the bose 3-2-1 system.
If you want something simple to setup, like the bose, and only need 2 channels, then check out the Denon S-101 system. Note, that unlike the Bose you get a subwoofer in addition to the two speakers.
http://smart.denon.com/s101.asp
If you have a small to medium size square room, then the Yamaha YSP-800 might be a good option. The YSP will simulate surround sound and can be directly connected to DVD and other audio inputs.
If you don't mind a little wiring and setup then you should consider a 5.1 speaker system with an entry level receiver and DVD player. In you budget, BIC or Athena bookshelf speakers and an entry level Yamaha or Onkyo receiver would be a good combination.
Post your budget, room size, # of speakers (2.1, 5.1, or 7.1), and the number of components you need (speakers, receiver, DVD, etc.) and you will get more specific recommendations.
agarwalro
agarwalro
The surround experience with less than 5.1 setup will be highly unsatisfactory. Why are you constrained from setting up rear speakers?
csmith15
The Room is roughly 300sq ft, give or take a little. Not sure right at this moment. I would like to keep my budget around $700 or less if possible. I am constrained to a 2.1 system for 2 reasons. My wife does not want any wires, and also I have cats that love to chew on them. I'm sure I could set it up where neither of those would be a problem, but I'm not sure it is worth the hassle. My ears aren't that finely tuned, so I'm not sure that would matter to me as much. Also, the 3-2-1 system does come with a sub. Thanks for your replies.
jcPanny
jcPanny
Bose 3-2-1
Ok, the Bose does include a "Acoustimass module". However, don't mistake this for a cute little subwoofer. In my opinion, you need at least an 8" driver and must be capable of producing frequencies below 60 Hz to be classified as a subwoofer.
Check the AH reviews of the Denon 2.1 system and the Yamaha YSP. Both should meet your asthetic and wiring requirements.
5
5.1 DTS guy
Have you considered some home theater in a box systems that have wireless rear speakers? There are alot of them from panasonic if you're on a budget and don't care too much about premium sound.
