I know there is a lot of good advice on here so I am hoping you can share some with me. We are moving into a new house and I need to upgrade my speakers. The wall that the tv goes on is right when you come down the stairs, so floorstanding speakers are out. Also, the back side of the tv wall is unfinished as it is the utility room (I plan to keep all components in there and run an IR repeater to control everything). Will in-wall speakers even work if there is no sheetrock on the other side of the wall?
Ideally, I would like one of two scenarios. First, if in-walls will work then I am considering doing the front and center as in-walls with a set of surround speakers for the rear (non in-wall). The other option is doing all on-wall speakers. I just want to get the best sound for the money and am also worried in-walls won't get me that. The room is just shy of 16' wide by 20' deep with 8' ceilings.
I have really been looking into a 5.1 RSL CG23 system, but with the wall mounts the speakers will stick out about 11" which seems like a lot to me and I am worried it will look odd. My absolute budget is $2000 for the 5.1 system and hoping to stay a little under. I know it isn't a huge budget, but I would like to see what you recommend. I really appreciate any and all advice!
