So if you are now going with the bookshelf idea as Dapack suggested, then you likely want some recommendations to start your list, yes?
My only recommendation is a pair of Paradigm Atoms v.6. MSRP is $299 for the pair and this is USD. Not sure what it would equate to in canadian currency. An advantage for you being in Canada is that Paradigm is a Canadian company, so you likely wouldn't even have to worry about shipping or import/export fees.
Of course if you aren't near a paradigm dealer, then you would have to make a trip to go audition and then buy them. I am biased, but I love mine. They are definitely worth a listen if you have the opportunity.
