Need Recommendations For Reciever For This System
MinusTheBear
MinusTheBear
I am interested in a new 7.1 reciever with a price range between $400 - $700 dollars to run these speakers.
My speakers are as follows:
Fronts: Axiom M3v2 8 ohms
Center Channel: RCA 8 ohms
Rear Speakers: Cerwin-Vega Sat-6 100 watts 4 0hms
Additional Speakers: Altec-Lansing Indoor Outdoor Speakers 80 watts 8 ohms
The problem is with a new reciever i want to put the cerwin vega as my rear speakers but the impedence on the CV are 4 ohms while all my other speakers are 8 ohms so i would need a reciever that is compatible with 4 ohm as well as 8ohm.
Any reccomendations would be of great help.
As of right now i have a passive Cerwin-Vega sub but will invest in a powered sub in the future...
Seth=L
Seth=L
Only one new receiver I can suggest, the Onkyo TX-SR805.:D
But, if you don't absolutely need HDMI and some newer features, you can get one of these below for pretty cheap.:D
http://www.ecost.com/Detail/Receivers/JVC/RXDP10VBK REF/38672961.aspx
This was JVC's Flagship model, and is THX Ultra certified. This means it is fully capable of handling 4 ohm loads. I have the JVC RX-DP9, which is very similar. Here is a link to my impressions on of it.
http://forums.audioholics.com/forums/showthread.php?t=31972
Good luck:)
MinusTheBear
MinusTheBear
Thanks for the links i will definetely check them out!
