Need Receiver recommendation for existing speakers & amp
U
user name
Im in the market for a receiver and seeking for recommendations on a reasonably priced unit with quality comparable to the existing audio units.
Already have:
(2) Polk Audio VM 30
(2) Polk Audio VM 20
(1) Polk Audio DSW Pro 600 Subwoofer
(1) Polk Audio Surroundbar 50
(1) Yamaha Amp (model C-60)
Thank you.
lsiberian
lsiberian
Already have:
Thank you.
Without a budget we can't make any recommendations.:D:);)
rnatalli
A budget would help, but I'll throw the Denon 2310 into the mix which can be had for about $550 right now.
Lordoftherings
Lordoftherings
That's a nice suggestion. May I add the Onkyo TX-SR707 to that list.
And for an even lower budget, the Onkyo TX-SR607 or Denon AVR-1910.
skers_54
You won't be able to use the amp with the Denons since they lack preouts. The Onkyo 707 has them, so you could use the amp with it. Might not be much of a difference between the receiver's amps and your yamaha though.
Lordoftherings
Lordoftherings
I wonder what is the true total percentage of people adding external amps to their receivers. Any guess? ;)
