ill find them, but im assuming that if those modules are good enough for Jeff Rowland Design Group, PS Audio, and Bel Canto Design(amoung others) that they will suffice.
from bel canto....
Power Output: >1000W into 4 ohms, >500W into 8 ohms
Minimum Load: 2 ohms
Frequency Response: +/-0.5dB 20Hz-20KHz, all loads
THD+N: 0.007% 1W, 1KHz, 4 ohms
IMD (CCIF): 0.0007%, 1W, 14:15KHz, 4 ohms
Output noise: 90uVRMS A-weighted 10Hz-20KHz
Voltage gain: 27dB (single ended or balanced input)
Damping factor: >1000
Output Impedance at 100Hz <8 milliohms
Dynamic Range: 120dB
Input Voltage for Max Output 3Vrms
Input connections: Single-ended RCA or balanced XLR
RCA input impedance: 10Kohms
Balanced input impedance: 20Kohms
Output connections: 1-set WBT 5-way safety binding posts
Standby Power: 15W
Size: 8.5x3x12[inches], 216x76x305[mm] (WxHxD)
Weight: 13lbs, 6Kg
ok reveiw
http://www.acoustic-reality.com/articles/eng_asp.pdf
