Need long A/V cables
G
gcmarshall
Me again. I need to find some cables in the 20-25 foot range. I need the following in that length:
- component video
- s-video
- composite audio (red/white cables)
- subwoofer cable
Can anyone suggest places to find good prices on longer cables like these? Are lengths this long even available for the above cables?
Many thanks again.
jaxvon
jaxvon
Well, they might be the cheapest, but you can get those lengths, and custom lengths of broadcast quality cable here:
www.bluejeanscable.com
Their S-Video cable is a special cable made by Belden especially for them. It's even better than the standard Belden S-Video.
RLA
RLA
Hello
If you are the DIY type you can use RG-6 for most of your cable need’s.
RG-6 and RG-6QS is a multi-purpose cable that can be used for composit, component, analog interconnects, digital interconnect, sub-woofer interconnect and s-video
A double run of RG-6 is perfect for long S-Vid runs a little tough to terminate but it can be done. Cost is about $80-130 for 500ft of cable, termination tool
And termination connectors.
If you want pre-terminated cables then Jaxvon's advice is solid;)
