Need info please...
G
graphicsgod
I need some advice.
I have just lost my Aiwa AV-D58 Receiver :(. It was my first SS system and hate to see it go. I'd like to fix it, but I don't think it's worth it. It stoped outputting sound, or at least after a few seconds of sound it would go silent. First started to the FM/AM, then the CD input, and then finally the digital went out. All within a year, this year to be exact. Had it for about ten years. Not sure what happened :(. I even checked the inside, no dust or burn marks of any kind :confused:.
So now I'm in need of a new reciever ASAP! So what reciever will work with my previous setup?!? All 5 speakers have 80W and 8 omes of power. Sub is 12V 60Hz. I don't want to spend a fortune. Just need a good reciever between $150-400, no more... no less. I was thinking about a Yamaha, since I've heard good things about em.
What do you guys think I should do or buy?!?
Rob
G
graphicsgod
Anyone?!? I'm in need of a new reciever. Is this the wrong place to ask or whats the deal?!
mulester7
mulester7
.....Graphics, I'd say get you $400 dollar's worth of Yamaha....wade on in there....your speakers are rated to take 80 watts and are 8 ohm speakers...."$400 dollar's worth of Yamaha to go, please, and fresh-dropped fries if you don't mind"....
jcPanny
jcPanny
Yamaha for <$400
I recently purchased the Yamaha HTR-5860 for just over $300 from an authorized dealer and would recommend it. With new models out, I would also check for deals on the RX-V1500 or HTR-5890 models.
G
graphicsgod
Cool thanks for the info!! So those brands are rated with the sub and speakers I have? I'd hate to buy something and have it blow something! I'll start "shoping" around.
Rob
