Need info on a Yamaha RX-V3200
starfish
I was in the market recently to purchase a new receiver. My price range was $400 max. I came across what I felt was a better deal on this used receiver that is in like new condition. I bought this model for much less than my anticipated cost (sniped it on eBay) and am more than pleased.
I have had a hard time finding any info about this unit and was hoping for some input. This receiver is equipped with a RS232C and in the manual all it says is that it is an expansion terminal for commercial use and to consult the dealer for details.
What exactly is this for?
Where there any software upgrades available at some time for this model?
What were the date's of manufacture for these models?
Any other info would be appreciated. Thanks.
BMXTRIX
BMXTRIX
Yamaha's website has a LOT of information on their products and old manuals, 232 codes, and IR codes for their products.
I believe the 3200 came out right before they had a major re-engineer of their products (the 300 series) which improved 232 codes and IR codes.
Really though, if you are using it for a single zone, the 3200 is a very good receiver.
I have not heard of Yamaha ever upgrading their product software. Ever. The 232 port allows serial (text) communication between a computer or control system and the receiver. Products from Crestron and AMX can control the receiver and find out information about the receiver to automate receiver control. With the 300 series of receivers, Yamaha released software to control the components. So, you could set up your receiver entirely by a laptop and the 232 port, then STORE the settings you used in the room. If the receiver ever had problems or needed to go into the shop and came back completely uncalibrated, you could just load the settings from the laptop back into the receiver.
Mostly used for system control though.
surveyor
surveyor
Congradulations!!
:) The RX-V3200 has a very good (beefy) power supply. The power supply is much better that the RX-V2400 or RX-V2500. It does not of course have some of there whistles and bells, but it is a superb reciever!
In lamens terms the RS232C connector is for technicians to troubleshoot the unit.
Cheers
starfish
I looked on the product information website and didn't see any upgrades available and thought that maybe they had it listed elsewhere. I spoke with a in store audio salesman once awhile back and he said something about some receiver's having these types of connections which removed the fear of obsolescence. He made it sound like all I needed to do was upgrade the software and I would have the latest surround formats. Maybe this happens with some brands more than others. I am still setting this unit up and appreciate your comments.
surveyor
surveyor
Here's some code for the 3200 with instructions attached.
Cheers
