• Thread starter Thread starter pamj46
pamj46
I need help in putting together a new Apex dvd player and a old funai, and sanyo t.v. How do i set them up together. And i don't have a cable box, my cable comes out of the wall.
If your TV does not have AV inputs you will have to purchase a RF converter. This will convert the AV output from your DVD player to RF (like your cable) then an A/B switcher will handle the two RF inputs. Using an RF converter will cause degradation of the signal from the DVD player. A new monitor/TV with AV inputs is the only way to take full advantage of the signal quality that a DVD player can give. :cool:
Thank you
Thank you i'll get one.I hope that it works. Sure would like to play some disc.
Thank you so much,i'll go and get one,i hope it will work i sure would like to see some movies
