joavan
I just bought a harman kardon avr 635 receiver to go with my Jbl l65 and Altec model 15 speakers but I cant make it work, every time I turn the volume up it shuts off I thoght I could not go wrong whit it but I dont know what I did wrong.
joavan
need help programming avr 635
I just bought a harman kardon avr 635 receiver to go with my Jbl l65 and Altec model 15 speakers but I cant make it work, every time I turn the volume up it shuts off I thoght I could not go wrong whit it but I dont know what I did wrong.[/QUOTE]
Adam
Adam
joavan, welcome to the forum.
Would you please explain a little more about what the problem is? Is it just that it shuts off when you turn up the volume? If so, how high up do you have the volume before it shuts off?
Seth=L
Seth=L
My only current suggestion is to check your cabling, make sure they are not shorted anywhere. Try using different speaker cables (I have had cables that appear to be fine, but are damaged anyway causing shorts and risking damage to equipment). The JBL L65s and VOT Altecs are efficient speakers, but I cannot find any specifications or bench tests for them as my internet is quite unresponsive at the moment. It is possible that the JBLs and/or Altecs dip very low in impedance at higher levels and lower frequencies. If you have a subwoofer you should be sure the cross-over on the receiver is set to 80hz or higher with the speakers set to "small". I know setting such large speakers to "small" seems to defy logic, but it helps to protect the receiver from low impedance dangers brought on by otherwise very efficient speakers. I am assuming that you don't have a subwoofer, as it wouldn't be very logical with such large speakers that can produce large amounts of bass.
Did you have another receiver connected to these speakers before? If so, what was the make and model of that receiver and did you experiance similar troubles using it as with the H/K. The H/K seems like a very capable receiver, but those speakers, surprising as it may be, may be more than it can handle.
markw
one step at a time.
First, disconnect both pairs of speakers.
Now, connect one pair up to the front R/L and play it in the stereo mode.
Does this work?
If so, the next logical step would be to connect the other pair, most likely to the rear R/L outputs, correct? Adjust the receiver to play in a phantom center mode (RTFM)
What are their impedances? I'm assuming both are at least 8 ohms. correct?
Where, exactly, do you have the speakers hooked up now, anyway?
