Yes.... you can either run the Optical cable out to the receiver, if they both have that... or you can run the red/white to one of the inputs on the receiver.
Both cases will work just fine...
Sounds like a long run might be in order.... You can get cable with no ends on them and solder the ends on once the cable is run...
