billy p
billy p
I've listened to NAD T743 and DENON 2106.But living in the great white north I can't just walk into shop and hear OUTLAW 1070? Input would be considered very helpfull!
jcPanny
jcPanny
Receivers
NAD or Outlaw are usually preferred for their 2-channel music performance and power into low impedence speakers, but any Denon or Yamaha mid-fi receiver should be more than adequate for your Athena speaker system.
billy p
billy p
Ok! With me having bookshelf speakers (8ohm) I will eventually get floors.My budget is approx $800.00 to a max of $1000.00 where should I look or invest!
billy p said:
.But living in the great white north !
Toronto? It is a big enough city to find the Outlaw up there, no?
billy p
billy p
All the reading I've done sounds to me Outlaw sells directly online to public. I just want to gauge their sound and proformance to Nad and Denon for starters?
N
Nick250
I wouldn't obsess too much about the receiver since IMO it plays a minimal role in the sound quality compared to speakers and room acoustics. The Denon would be just fine since I believe it has pre outs in case you want to add an external amp down the road.
markw
Instead of looking towards spending $$ on floor-standers, you might want to consider standing pat and investing in a great sub instead.
Those Athena's are incredibly efficient and should have no problem deafening you with either receiver and sounding great while doing it.
billy p
billy p
Mark, good angle with sub upgrade! Just want to buy the best avr in my price range to handle both H/T and music that's why I want floors later?:)
I keep forgetting this:confused:
billy p
billy p
Thanks To Help Question
Thanks to all who took the time and gave some insight. I now am the proud owner of a denon avr 3805 I will be posting some question once everthing is set-up GULP!!:D
