Need help with upgrade
L
Luiz Vacanti
Hello,
Back in 2017, you guys helped with my upgrade.
Now I’m looking forward to upgrade my speakers again, back in 2017 I bought 3 Philharmonic Audio Accuracy Monitor.
My budget will be between 1000 - 1500 pair. My receiver is Denon avr-x3300w, also a Panasonic Blu-Ray and a Technics SL 1200MK2. SVS SB12 Subwoofer.
My room it is 10x10.
I leave here in the US.
Some contenders are:
SVS Ultra Bookshelf
Elac Unify Reference
Kef LS 50 Meta
Klipsch RP-600M
Please, what do you guys think about these speakers any other suggestion?
After the speakers the next upgrade will be an amplifier, maybe a Tube amp.
Thank you very much for your help,
Luiz V
I'd still look at Philharmonic even if your budget is limited, you could still diy a pair of BMRs within it I believe, or save up a bit for a Salk version. Ascend Acoustics has some nice offerings to consider. In your list I'd leave out the Klipsch myself and maybe just start off with an in-home trial of the SVS while you consider options but overall hard to know what speakers you might prefer as its a fairly personal choice. Which of these have you had any experience with?
I wouldn't call a tube amp an upgrade myself....
Mikado463
Mikado463
small room and it's square, never a good thing. Have you address room acoustics ? If not, I'd start there first
Eppie
Eppie
The SVS, Elac and KEF are all good options. The LS 50 Meta is an end game speaker for a lot of people. A Philharmonic BMR kit runs around $1000 for the drivers and crossovers but then you need someone to build the cabinets if that's not within your skill set. You'd end up with a $2000 speaker that performs as well as a $3000 speaker, though. ;) The rectangular BMRs are $1700 and last I heard are in stock. The curved BMRs are $1900 but waiting for the next batch of cabinets. You should have a look at the Philharmonic site again as the BMRs are only a couple of hundred over your budget.
shadyJ
Speaker of the House
Staff member
The tube amp is very likely to be a downgrade. Don't be fooled by any claims of fidelity, and only get it if you like looking at Vacuum tubes.
-Jim-
-Jim-
I wouldn't call a tube amp an upgrade - more like a tone control for most.
L
Luiz Vacanti
Didn’t have any experience with the speakers yet. Very good idea about the SVS, maybe I can do the same with Elac.
I like the idea of use tube amp with my turntable, but for now it is just an idea. Need to do some room treatment also. Thanks.
L
Luiz Vacanti
Yes, definitely need to do some room treatment before. Thanks.
L
Luiz Vacanti
I like to use the tube amp with my turntable, but this is just a thought for now. Thanks.
SVS will pay return shipping if you don't like them, RSL has the same offer but many others, even if they have an in-home trial period, will not pay return shipping so look at terms carefully.
