I need an opinion on the following. It is for a bass guitar/keyboard rig I am building.
Pyramid W64 6-1/2" Pro Plus Midbass Woofer
4x6.5
16x8x16(no bracing)
0.5" Plywood void free 5 ply
3 1x1" ports 8.35" long
or
3 1" diameter ports 6.4" long
*Power handling: 100 watts RMS/200 watts max *VCdia: 1" *Impedance: 4 ohms *Frequency response: 65-3,600 Hz *Magnet structure weight: 30 oz. *Fs: 67 Hz *SPL: 96 dB 1W/1m *Vas: 0.02 cu. ft. *Qms: 3.72 *Qes: .93 *Qts: .74 *Mfg. #W64 *Two-year manufacturer's warranty *Dimensions: Overall Diameter: 6-1/2", Cutout Diameter: 5-3/4", Mounting Depth: 2-3/4".
Eminence Delta-12LFA 12" Low Frequency
1x12
18x16x32(braced)
3 5x2 ports 15.75" Long
Specifications: *Power handling: 500 watts RMS *VCdia: 2.5" *Le: 1.45 mH *Impedance: 8 ohms *Re: 6.06 ohms *Frequency range: 44-3,000 Hz *Magnet weight: 56 oz. *Fs: 51 Hz *SPL: 94.6 dB 1W/1m *Vas: 2.4 cu. ft. *Qms: 7.28 *Qes: 0.51 *Qts: 0.47 *Xmax: 4.8 mm *Dimensions: Overall Diameter: 12.03", Cutout Diameter: 10.95", Mounting Depth: 5.35".
