Need help with LED Lights
Y
Yuriy
Hello everyone. I need some help finding lights for my home theater.
1. I have a TV mounted on the wall and I want it to be back lit. This would make the wall have a soft glow.
2. I have a thick curtain behind the couch and I want lights from the ceiling to softly change colors. RGB would look great.
3. This is the hardest thing to find. I want to place lights behind the floor standing speakers that glow to the sound. As the beat changes, I would like the intensity of the glow to change. My receiver would have to be plugged in to a LED Controller I think.
Your thoughts, suggestions, and opinions are greatly appreciated.
Yuriy
Adam
Adam
Hi Yuriy, and welcome to the forum!
These days, there are a number of options out there for RGB LED lights. There are regular bulbs, thin light strips, bulbs with speakers in them, and so on. There are also products that will change color/intensity with sound. I say do a quick search on Amazon.com, and you might find everything that you want. I did a very quick search there for "sound sensitive light" and got a number of hits, including this RGB light strip.
Y
Yuriy
Thank you Adam. I was looking for the name "sound sensitive light".
As I am digging deeper into this, this project is becoming very complex. Because I need 3 different sets of LEDs this means that I will need to be able to turn them on and off individually. Best option would be to use a wall switch for each LED group so that I don't have to use 3 different remotes. Hopefully once the options on the LEDs are set, they will not change after turning them off.
